1 - 20 of 53 Posts
SOLD!
I am parting out my 1987 Mustang GT that I bought when I was 17 (30 now) in order to pay for my wedding. This is the listing for the engine. The engine can be bought as a complete engine (without front accessories) or longblock, or shortblock only. Engine is currently in the car and runs. Engine has only 1,531 miles on it. Never Drag Raced. I have all of the engine paperwork.
-347 Dart Engine assembled by "Woody" at Ford Strokers.
- DART 347 Liberator Shortblock
-Dart SHP Machined Block
-Scat 4340 Forged Steel 3.400 Crankshaft
-Scat 4340 Forged Steel H Beam Connecting Rods 5.400 with ARP 2000 Rod Bolts
-Wiseco 2618 Forged Pistons 4.030 (Flat Top / -5cc / Inline Valve Reliefs)
-Wiseco GFX Ring Package for 10-15lbs of boost
-Clevite 77 H Main and Rod Bearings
-Dart Coated Cam Bearings
-Screw in Oil Galley Plugs
-Fel Pro Rear Main Seal
-ARP Main Studs
-Freeze Plugs
-Custom Hydraulic Roller Camshaft by Comp Cams (For Boost)
-Intake Lift .566 and Exhaust .550
-Lobe Separation 113.0
-Duration @ .050- Intake and Exhaust 214
-Have Cam Card
-ARP Cam Bolt
-SA Gear Billet Timing Chain w/ Torrington Bearing
-Melling Select High Volume Oil Pump (part #10688)
-ARP Oil Pump Bolts
-Moroso Oil Pump Pickup (part #24519)
-ARP Billet Oil Pumpshaft
-Fel Pro 1 Piece Oil Pan Gasket
-Moroso 7qt. Oil Pan (part #20511)
-Powerbond SFI 28oz Balancer (part #1060-ss)
-ARP Balancer Bolt
-ATI Billet Adjustable Timing Pointer
-AFR 195cc Renegade Heads
-20 Degree 75cc Exhaust Ports and 195cc Intake Ports
-72cc combustion chambers
-2.020" intake valves and 1.6" exhaust valves
-Upgraded springs standard
-Cometic MLS Head Gaskets (9.0:1 Compression Ratio)
-Compression can be raised with thinner MLS Gaskets
-Comp Cams Ultra Gold Roller Rockers
-ARP Head Stud Kit
-Comp Cams Pushrods and Hydraulic Roller Lifters
-Trickflow Valve Covers
-Trickflow R-Series Upper and Lower Intake Manifolds
-ARP Intake Manifold Bolts
-Accufab 75mm Race Throttle Body
-Ford Racing Water Pump
-ARP Water Pump Bolt Kit
-Ford Racing 28oz Flywheel with ARP Flywheel Bolts
-MSD Pro Billet Distributor
I am probably missing something so just ask. My name is Joe and my email is [email protected]. Can email photos. Serious Inquiries Only. I am located in Carlisle, PA but can also meet near Hershey, PA. No Shipping. Complete Engine (parts listed above) = $7,500. Longblock = $6,500 (VC included). Shortblock (oil pan included)
SOLD!
Sell car to pay for wedding!!!!???? The hell with that nonsense!!! Sounds terrible. Don’t do it. .......sorry I had to.
I know it’s a dumb idea but if I have some money left over there might be a Miata purchase for road coarse and auto cross. Which could eventually turn into a V8 conversion with a push rod 302.
Discussion Starter #17
Still looking to sell the motor complete as a long block or short block.
I'd be lying if i didn't consider this motor. It's just a little out of the price range i'm looking for. What are you tuning with?
1 - 20 of 53 Posts
