1988 Mustang GT 351w 40over balanced stock crank arp main studs.race prep truck rods with arp bolts,KB flattop pistons 10.5to1 comp,plasma moly rings,canton 7qt oil pan,melling high volume oil pump,clevite77 bearings,dart sr iron heads ported 2.02/1.60 valves,lunati solid flat tappet cam 563/568,victor jr intake,holley 750 dp carb,msd ign.Less then 500 miles on motor.Race prep pan fill C4 trans manual/reverse valvebody with transbrake,tci 3500stall,hurst quarterstick shifter,12gal fuel cell,holley blue pump,steel braided fuel lines front to back,relocated battery in hatch,6pt roll cage,auto meter tach with shift light,oil press,water temp,egt gauge and fuel gauge,full interior with new carpet and 94gt front seats,megabite jr lower control arms,adjustable uppers,subframe connectors,4in cowl hood,weld draglites 3.5front 8in back,8.8 rear with 373 gears,I have not taken it to the track so I dont have any times.Asking $5000 I am located on the Va/Nc line.My email is [email protected] I have pics.May consider trades
