D&D Tubular K member - Manual Rack Line - Lock - Lakewood 90/10 struts
Manual brakes - 87' brake upgrade
Coil-over front springs - 4:10 FMS gears
31 spline spool - 31 spline Moser axels
C-clip eliminators - 50/50 Lakewood shocks
Southside lowers - adjustable uppers
TA girdle - Torque boxes welded and housing
6 point bolt-in cage - race seat and 5 point harness
Monster tach/shift lite - EGT,oil,water,fuel gauges in dash
MSD 6AL - MSD 2 step
8 gallon cell - Holley blue and filter
Weld draglites(new skinnies,ET drags)
4" cowl hood - B and M ratchet shifter
Chassis is solid and clean. Completely welded seams and painted underside. Inside is gutted and painted silver. Car weight with driver was 2600 with drivetrain. This chassis with a hyd. roller N/A 306 went high 10's. Exterior is solid and blue, paint is so-so(garage paint job). All you need is motor and tranny. Set up for C4. $3000 and can help with delivery.
Discussion Starter · #2 ·
Forgot to mention. Has a 85' nose and quarter windows.
Discussion Starter · #4 ·
yes, pics on the web. they are at www.momsracing.com. Look under cars for sale. Its the 3rd down, 80' notch w/ 85' nose. Let me know if you need anything else.
pics dont work
suggested this to my bro
if you still have it in the spring he might be interested in looking at it
if it comes down to it I'll give you a buzz
I'm looking for 4.6 eek....
Discussion Starter · #6 ·
hondatek88, you'll have to type in the website name. The link is not working....
