I can't rid my car of the exhaust leak. With window down exhaust circulates into car while driving. Same with old or all new exhaust, replaced hatch seal and adjusted, no visible leaks in exhaust. I have checked entire car and can find no visible locations for entry of exhaust gas. Please help, out of ideas. It does not come in through vents with air on or off. Only enters the car with window down.
Check under the hood real good. If the exhaust isn't leaking (manifold, O2 sensor, etc.) make sure you don't have a valve cover leak or something. When the heater is running, it will draw air in from under the hood.
