Mostly correct. As written, that’s the typical arrangement for a mod motor. Locations don’t have to be on valve covers. A typical pushrod engine will have the PCV valve in the back of the intake manifold where it draws from the valley under the intake and the fresh air line to a valve cover (oil fill neck).You need a PCV valve on one valve cover and a VENT on the other valve cover to allow your PCV to work correctly..
I am guessing your PCV is drawing a vacuum with NO source of air INTO the engine... I have seen this before..
To generalize, a correct PCV system will have a PCV valve placed with access into the crankcase and have a hose running from it to a vacuum source. The fresh air tube will connect between a different crankcase location and a metered air source pre throttlebody (assuming MAF) that won’t see pressure if forced induction.
