1 - 11 of 11 Posts
My stang has a rebuilt engine with the mods in the sig... everything else is stock, including the original E7 heads. WHen I first got the car the engine made a ticking sound and it is constant through all rpms. I changed the oil and the noise is still there, it may be my imagination but it has gotten louder.... it sounds like a train almost. THe ticking sound is louder than my exhaust at idle!! It sounds like its a valve train problem opossed from a exhuast leak. How can I tell from the 2? I dont feel any air leaking from the heads/headers.
Well I popped off the drivers side valve cover and 2 of my rocker arms were loose! But I tried tighten them down but the bolt is bottomed out and the rocker arms are still loose. These are the stock arms. What could cause the rockers to stay loose. I could see if they were all loose but its only 2 of them!!
sounds to me like a bad lifter. try and put a product in it called Resinol (sp?) follow the directions and it should clean out the lifter if not new lifters are the fix.
there are no shimms on the rockers
Well Ive been driving the car like this for about a month and a half. So hopefully it can last a couple of more days till I get time to pull the lifters out... thanks guys!!
Well I fixed the ticking guys. I pulled the lower intake off and swapped lifters in the 2 bores that had the loose rockers and the rocker arms STILL didnt get tight. I then replaced the pushrods and swapped rocker arms from cylnder to cylinder and they still wouldnt get tight. So I cleaned the bolt hole inside the heads and wah-laa, they both bolted down correctly and they arent loose any more and NO MORE TICKING!!
1 - 11 of 11 Posts
