Just install an on3 turbo on my 86Gt. Engines running at 205degrees. It that high or normal. I have a 3core radiator twin electric fans and a 7qt oil pan. Think of adding a oil cooler not sure if it we help. Any suggestion would greatly be appreciated. Steve:cool:
That's about where mine is running now that summer has hit. Mine never moved off 180 before the turbo install. I have an aluminum radiator with twin Contour fans, FWIW.
Mine runs at around 180 degrees....i have noticed tho when in boost it will creep up then come down after i start driving its normal again...im sure its the boost meaning uping the heat...
