I was wondering if anyone can help me out I have a noise that is coming from either the rear of the engine or front of the trans. It is a low pitched squeak noise that gets faster if you hit the gas, and sounds like metal to metal rubbing. I pulled lower cover off the trans (AOD) and the flywheel looked ok, I also checked the starter and its ok, the engine runs fine and the trans is ok shifts fine. Also I checked the fluid level of the trans and its ok. Does anyone know what this could possibly be or had this before? It is pissing me off cause the car sounded good before and now it sounds like its worth $2, somedays the noise is loud and sometimes not that bad. Greg
