1 - 1 of 1 Posts
96 cobra diesel sound if you listen to the intake ?? is this the plates under the intake or is something wrong with it ?? second engine is very noisey (value train) when cold when started after it warms up it quits down ?? checked oil pressure 90psi when cold goes down to 30 psi after warmed up !! any input would be great thanks corral!!!! chad
1 - 1 of 1 Posts
