I bought some FMS valve covers for my Cobra and would like to make sure that the three little screws holding the oil baffle inside the cover do not work their way out and into my heads. The only thread lock that I have is good up to 300*F. Does the valve cover get this hot? I've had trouble getting T.lock that is good any higher than 300*F?
Jeff
Thank you!
Let's put it this way, if it gets much over 300F at the underside of the valve cover, you're probably gonna have other problems in addition to those little fasteners.
:D I catch your drift :D
