I am using the anderson valve covers that are vented to a catch can. It is bone dry but someone mentioned that I could need a vacuum evac system? I have never heard of anything like this so I am currently investigating that.if it is the rms, take it out again if it's really bothering you, put it in a stand, remove the oil pan, remove, the rear bearing cap, remove the old rms, install a repair sleeve, install a regular felpro seal, put some black silicone on the outer edge of the bearing cap, install the bearing and cap, torque to spec, install a blue fel pro oil pan gasket, tighten the bolts.
use permetex #2 on the flywheel bolts and torque to spec.
Thats if it is the rms leaking of course.
How are you venting this engine?
If this engine builder spent 15 minutes with me and actually suggested some of these ideas I am getting here from you guys then this post would probably have never happened. That is what some people are missing, my point is the customer service and help side, non-existent from this company.
If you own a business and call me annoying like the dude in the above post said, then sorry you should not be in this business....
