I think you might be missing a point here. Hear me out, we are dealing with aftermarket performance parts here and no matter how expensive or how good they are things fail. You can have the best engine builder in the world build something and have the best parts on it and stuff still happens, things go wrong from time to time. When talking about performance engines its even more common, which is also a reason a lot of performance shops dont give long warranties (if any at all) for race stuff. As I said above, I have the same motor as you, and I have a procharger that pushes 21psi regularly, I pull my car in the garage after a night of cruising and usually a week later when I go to move it there will be a 1-2" circle of oil right under the bellhousing where yours is leaking. When I took it apart this winter it was the rear main without a doubt and I just thought, it is what it is, ive used the best parts I can and in my opinion a top builder in the world for SBF's. I have no doubt it has nothing to do with the build quality, but moreso that these fords just have a poor design at the rear main and theres only so much that can be done.It is what it is, at then end of the day I know what is going to happen. I am going to chase the leak, pull it all apart and find where it is coming from and at that point engine builder will say well it can't be that because I already fixed that or whatever and judging from the communication I have gotten since the first leak and responsiveness it won't go well. Like I said, I am not sure what could happen, what should happen blah blah, I was just curious what other people think or have experienced.
Maybe the moral of the story is, when you pay someone to do something take some time and have a serious discussion about the things that "may" happen and how they would resolve them. What is their responsibility or what falls under the category of "not much we can do".
Like I said, when I shell out that much money for something I expect it to be perfect. Not much more I can say here so take it for what it is worth and question/set expectations before you commit to anything.....
Also why not just say the builder? So others can chime in if theyve had the same issues? Maybe that would help to know if its a common occurrence with the parts they use, etcAlso, at the end of the day, **** happens people make mistakes.. This guy could have built 20k engines and it is always possible to have one issue, one bad one.... hell maybe the oil pan is bad, maybe he used two bad seals or gaskets...I dunno. I however think communication and resolution are two important factors, which in this case left a lot to be desired....You can build engines and be buddies with all the engines that came out good but this just showed me that in this case when things do not go well sometimes the business doesn't wanna be your buddy anymore...
Yea man I agree. At the end of the day I know it is going to be on me having to figure it out.Seems like $11,500 of the $12,000 build is working perfectly. If it was me I would take it apart and see what, if anything, was done wrong. Then you have a case.
I think again everyone is missing my point, The engine was not even broken in and it was leaking oil......A drop of oil on the floor from a boosted application will not ruin the builders reputation at all. Throw it out there.
trust me that it won’t make a lick of difference for his overall reputation and how he is viewed on the Internet by the vast majority.I think again everyone is missing my point, The engine was not even broken in and it was leaking oil......
Cool thanks let me check it out.![]()
My custom Electric Crankcase Evac
I'm not going to get into a debate with those who think an electric crankcase evacuation system is not or should not be needed b/c I have my own reasons for wanting one: To minimize any oil leaks....and they work. I had one on my GN and after I sold it having one on my Mustang was a necessity...www.corral.net
Here is a topic from this site you might find helpful. May also make you feel less alone with this issue. If nothing else an affordable and simple solution.
Lots of people install Teflon seals incorrectly. Teflon seals are installed 100% dry, you even have to clean the crank so there is no oil residue. If installed correctly they seal well.. mine has one and doesn't leak. Have you had bad experiences?Was a Teflon rear main seal used?
I do hear you, maybe its just a simple misunderstanding why you werent informed. I know when I had mine built I called and talked to him, asked him a million questions and he answered them all. One question I had was "will I be forced to run a vac pump because I dont have room to", he responded telling me "its a boosted SBF, it would greatly make a difference running a vac pump, if you simply cant, I wouldnt lose sleep on it but dont freak out if you see a drip of oil after beating on it". Would he of come out and said that had I not asked? Probably not honestly.I agree with you 100% but with one caveat.....
Virtually no miles, just broke in engine per builders instructions. I think your point applies more to if some time had passed, like a year went by and any number of passes at the strip and then i was pissed that something broke or started leaking....again this was pretty much from the get go....
Well, I have enough respect for this person to not say anything at least not now. The reason is like you said, he did a very nice deed to come and fix it the first time.
Like I keep saying, I am not sure exactly what to say, what to expect, it is a ****ty situation for the builder and myself. I do know one thing that if I was a business owner I would going above and beyond to communicate and try and help me work this out or just freaking say, no there is nothing i can or will do!!!
Before and during the build, amazing communication, AMAZING, as it should be. After the issue, pretty crappy. Excuses and days before getting an email response, this was from the first instance of the leak, not just the second time....
Even if they can and will do nothing, there is no excuse for such crappy communication.
So this is where I tie the story back to you and what you said. So if it is what it is then i feel the builder, the "expert" should caveat this up front. And then maybe I wouldn't be pouting like a little kid right now. As I said before, maybe it is the duty of the customer to ask and pry up front and but I still find it hard to believe that a leak like this is normal though, ESPECIALLY right away....
I do hear you though, we are dealing with old designs, this is not a 2022 engineered engine...but at the end of the day, any reputable shop or business should be able to return an email within 24-48 hours and not a week and then keep giving a run around either help me or just tell me to go pound sand, which i feel is what they are silently telling me to do lol.
I am sure I am not the only one here that dropped some good money on an engine, just curious to see if anyone else that has had an engine built had an issue like this.
I used loctite on mine. No leaks...yet.oh nooo noo. The first time I put it togehter I used loctite and he said it was leaking there because I used loctite and not thread sealer. But with the loctite it was not leaking there. yea I agree with you. I have seen debates online whether to use loctite or thread sealer but in the end I have heard both work fine I just used thread sealer when I put it back together after he fixed it the first time so he could not use that against me again....
Like I said, drop 12k, get no reply to your emails and then let me know how you would feel. I have done a lot of business with many companies over the years and there are the ones that are your friends before you pay them and ehhhhh not so much after (whether or not things go bad) and then there are the ones that treat you well before during and after no matter what they make time.Communication is probably bad because he thinks you are annoying him about a drip of oil and hope you will just leave him alone.
