Does any body know if I could pass emissions in Mass without my smog equipment,I do have high flow cats,and I currently pass the inspection........Steve
Well, technincally yes you need to have ALL your smog equipment, but if you look for certain small garages, they don't even really check too much...as long as what come out of the tailpipes is clean.
You have passed the IM240 dyno emissions test in MA? If you have, then you would fail the visual if you go to a place that actually looks. Like Mke was saying, if you can find a place that will "overlook" anything that is suppose to be there, you may be able to get a sticker.
There is no official visual inspection in Mass other than for the cats. Real visual test has factory drawings like calif does, and checks for all the parts even the wingnut:barf:
I had to go back for a second test with my stocker, but I just needed a fresh set of o2s to pass. Some have claimed passing hc's withot the pump, I doubt you'll have much luck
