Electrical problem 98 GT
636 Views 13 Replies 2 Participants Last post by  indy2000
I was wondering if anybody has any idea what is going on here.
On my 98 GT, my radio, interior light, speedo, power locks, power mirrors, headlights, and basically everything else does not get power for some reason. But the fuse box says everything is fine.
The only things that work are my blinkers, brake lights, and the engine. It runs and drives perfectly fine.
Does anybody have any clue why this is?
It happens randomly, it doesn't happen when I'm driving, it happens only after I go somewhere and park and go to leave nothing works. Then I'll park it at home for a few days and it'll randomly work again.
1 - 14 of 14 Posts
supply me clear wiring diagrams for you specific vehicle and it will be an easy fix
Will these do the job?
the grounds are not numbered
but if all those you say cutout
i would check the power feed to the fuse box, and the buss bar under it
only happens after a restart? i dont follow what you are saying about when it happens
be specific.
be specific.
It happens randomly. But not while I'm driving only after I park it somewhere. It has never went out while I've been driving.
And what do you mean by buss bar?
fuse box has a power feed, and looks like your breaker panel at your house
a bar carries the current to all the fuses.
you could have a lot of corrosion under there
Okay thanks.
And one more question, do you think bad circuit breakers in the fuse box under the dash causing it?
engine bay
remember i do not have wiring diagrams of your car, i am assuming you do to do this electrical work
Yes I'm trying to fix this myself.
So fuses # 4,5,8,13, and 16. Do not have power.
did you not say in first post fuse box is fine?
That's what I originally thought. Do you think the gem module could do this?
Wait a second
are you saying there is no power at the fuse box?
1 - 14 of 14 Posts
