my 90 stang's fuel pump will not work. i replaced both relays(fuel and eec). the pink/black wire going to the fuel pump still has no current. the ground is good. the inertia switch is ok. all fuses are ok. when i turn the key on all i hear is the eec and fuel pump relay click twice. no electricity is flowing to the fuel pump? what do i do next? the canal is not yet an option.:livid:
find the fuse link going to the fuel pump, looks like a wire, probably ok on the outside, but blown on the inside, I happened to buddy's car took us a week to figure out wtf happened.
the fuse link i think goes between the realy and pump. You can always use a jumper wire from the relay to fuel pump +12 wire and see if that works
kyle
