I am hooking up a dual Spawl electric fan and was wondering what Variable speed controller you guys recommend? I searched and read what people had to say and I think this would be the best for my application.
http://www.flex-a-lite.com/auto/html/vsc.html
What do you guys think? Is there a different route that I should take?
Thanks in advance....
Super Moderator
I've been using the heavier-duty 33054 for quite some time now, and I like it. They both have soft starts, adjustability, A/C-triggered auto-on, and the capacity to add manual overrides. The only thing is, the 33054 doesn't come with wiring, connectors or main fuse. I don't know what your SPAL fans are rated at, but if they're under 30 amps, you should be fine with the one you've picked out. Buy it at Summit and have it on your doorstep 3 days later.
