What solutions has anyone used to mount accesories(airpump and power steering pump) on a '89 with GT-40 turboswirl heads. The hole in the EGR passage too big for the factory bolts. On the passenger side it looks easy to enlarge the braket hole and change the bolt. On driver side power steering pump and 2 brackets will need to be drilled. Or is there an insert that I'm missing( bought the heads used). Anyhelp greatly appreciated. Bruce
yes, i believe you are missing the threaded inserts for the accessory mounting places on the front of the heads. i am not sure how to get ahold of these, when i bought my heads new they came with them....
Go to your local Ford dealer and tell them you need 2 of the threaded inserts for those holes - that will allow the accessories to bolt right up. It's the same insert used in the stock head. About $4.
