1 - 11 of 11 Posts
Banned
well ford neglecterd to ask me what eec i had, and i neglected to offer the info.(forgot) I know i have a cobra ecm, but here is exactly what it say. If they were to put its a 93 cobra instaed of 91 gt would they be able to pull codes?
EEC-IV SFIMA12A X3Z
F3ZF 12A650- CA
61SM12AF12 23563 -307 - R 1H07
WHAT DO I HAVE?
I'm not exactly following what you are saying.
The X3Z is the Cobra EEC.
Codes should be able to be outputted in any event.
Banned
ok, then i guesss it makes no difference, i must just have a bad ecm...ford cant pull codes, the machine just beeps at them.... they are stumped....
They should be able to pull codes regardless. Looking at your parts numbers, you have an X3Z, aka 93 Cobra processor. You will have to stay with the X3Z, as it is calibrated for your 24# injectors (unless you swap mass air meters).
Banned
Discussion Starter · #5 ·
will i be able to throw an a9l or such in there to check to see if its my ecm that is bad? I know it would run a little rich, but i just want to see if its bad....
It will run a lot rich if you do that. You could throw it in there at the dealership and not start it, just turn the switch to "on" and see if they can pull codes that way. If they can, it should read clean, but at least then you'll know they can read it, and then you can get a new X3Z.
Banned
Discussion Starter · #7 ·
you recommend a new x3z? and not an a9l or similiar?
I know you've read my HUGE post, what do you think it could be....?
I'm just saying that replacing your X3z with an a9l will not work unless you either:
• replace 24# injectors with 19# injectors
• replace mass air meter with one calibrated for 24# injectors.
I'm not sure which post you are talking about - is it the one about "switching to carb from efi"? If so, I haven't really gotten into that thread, since it was so long before I even saw it. It was at 3+ pages when I saw it the first time.
I'll try to check it out when I get a chance.
Banned
Discussion Starter · #9 ·
yea that would be the one, really havin trouble and cant figure it out, any help would be helpful, thanks jON
Can't find the thread, can you post me a link to it?
Banned
Discussion Starter · #11 ·
**** i cant figure that out, search under my name and you'll see it....
1 - 11 of 11 Posts
