Hi Guys,
I'm in need of a little help with an EEC-IV problem. I had a customer drop off his 1990 GT last week with a boatload of codes in the computer and running terribly rich. I've done the pin checks and studied schematics until I'm about to puke :barf: and I'm still not seeing the problem. Maybe one of you guys will see what it is that I'm missing.
Here's a quick rundown of what I've got:
1990 GT with an A9L processor
Completely stock motor except for an A-Trim, 30# injectors and matching C&L
A little history:
This guy bought the car with a race motor in it (running just fine) and he also bought a lightly wrecked stock 1991 LX (wrecked so light that it ran and drove fine). He took the race drivetrain out of the GT and put the entire drivetrain out of the LX in it. In the process of getting it all running, he managed to cross up the battery cables for a split second. I don't know if this is at all related to the problem, but I'm thinking its a strong possibility. Anyway, he got the car running and it ran poorly so he swapped the processor with a known good one (also swapped the alternator, just in case) but it ran just as poorly.
As the car was brought to me, it was flooding like there was no tomorrow and the Check Engine Light was on. My assumption was that it was running in "Limp Home Mode" and couldn't compensate for the 30# injectors, hence the flooding. Anyway, it initally showed the following codes: 51, 22, 53, 54, 35, 67 and four others pertaining to the missing smog equipment (which I'm disregarding). I cleared the codes, re-ran the KOEO and came up with the same codes.
After a long (and I mean LONG!) two days of pin checks and testing, it started registering a different set of codes: 21, 22, 23, 24, 34 and 67. Not sure if I pulled something or what, but now its registering a bunch of codes related to the SIG RTN. What struck me as odd is the fact that when the clutch is depressed, the car runs much better and the Check Engine Light goes off. As soon as the clutch comes up, the light comes back on and it goes to flooding again.
Here's where it gets really weird: After some testing and checking, I ended up pulling both of the plugs off of the clutch interlock switch (one plug for the starter solenoid - red/light blue wires and the other for the ECM with black/white and light blue/yellow wires). I thought maybe the switch was bad and possibly bleeding voltage from one side to the other. Then I jumpered each plug, ran the KOEO and the codes were gone. Long story short, the jumper in the starter solenoid side of the switch causes the codes to dissapear. Sounds crazy, I know, but its what I've got. I verified it by cranking the car and removing the red/light blue trigger wire from the starter solenoid. As long as the wire is attached to the solenoid and the switch on the clutch pedal is jumpered, the car runs OK w/no Check Engine Light. As soon as you pull the wire off the solenoid (or remove the jumper wire) the light comes on and the codes 21, 22, 23, 24 and 34 re-apear. I also checked resistance from pin 46 on the ECM to ground and its 2 ohms with the solenoid wire hooked up and 600+ ohms when unhooked.:curses:
What am I missing here? I can't find a relationship as far as why the SIG RTN goes away when the starter solenoid trigger wire is unhooked. I still feel like the ECM is not 100% right because I have tried both of these in another car in the shop and it runs poorly with either of them. My problem is that I hate to go putting another known-good ECM in here because there's a problem somewhere that smoked the second one. I don't want to kill a third one for no reason.....
A couple other things to note:
I have verified that there is no continuity between pin 30 and the clutch switch, which I know needs to be fixed. I don't believe this is the problem, though, because that circuit is not complete anytime that the car is in gear and the clucth is up.
2 ohms to ground on pins 20, 40 and 60
Keep in mind that the battery was momentarily hooked up backwards - may or may not have any relation to the problem
I apologize for the long read, but I'm at a loss. Its probably something so stinking simple that I'm overlooking it, but I don't know what it might be. If any of you Ford Techs read this and have other questions, I have about 10 pages of notes pertaining to voltages and resistances that I've recorded in my checking things. If you need more data, I've probably already got it so just ask.
Well, I guess that's about it for now. I look forward to see if any of you guys see something I dont in all of this!
Many thanks,
Deron
A little history:
Many thanks,
Deron
