I've been trying to find a good intake for my car. Basically best bang for the buck. I want to use the Trick Flow Track Intake because I want to make power to about 6k. I will be using Gt-40p heads to bolt down to. I have heard the Trick Flow isn't a good choice UNLESS I port it out to have a port-matched set-up. On the other hand I have always heard great things about their intakes.
As for Edelbrock...this guy out here in Vegas put a Edelbrock intake on his pretty much bone stock 95 GT and got 22hp.
Who makes a better intake??
I would like to use a FMS intake but they are expensive and I would really only want to use the GT-40 intake.
What do you guys think?:confused:
If you are going to compare which intake is better ported I'd say the edelbrock because you have easy access to the upper. If you want a unported intake go with the TrickFlow.
