Is anyone running a eboost boost controller ? If so did you hook up your RPM signal to the eboost controller ? How did you do it ? Do I need an adapter like a Auto Meter tach adapter model 9117 or can I just tap into the ECU RPM signal ?
I know the Eboost controller needs a square wave switching between 0V and 3.5-12 volts .
I have been searching all night and Ive only gotten as far as I might need a tach adapter :livid:
