1 - 9 of 9 Posts
can i bolt on a set of e-7s on my stock 86 5.0 without the comp going crazy?? thanks
I just tried to do the same swap on my 86 vert and did not have enough piston to valve clearance and I have a stock cam so be carefull
i didnt check on mine..worked fine..taken it over 6000rpms a couple times
definiely brings compression up though..I got real bad pinging on mine when I first started it up, but it just took some carb adjusting to rid of it
Checking is just insurance all motors are not the same I would just hate to see him just bolt them on and next thing you know there goes some bent valves
oh i agree..not all engines are the same..if its easy for you to check p/v then go for it...I didnt have the right tools to check it on mine so I just took the risk...
I think youre the only person I know of who had a p/v problem with it. Do you have any reason to believe your heads could have been milled? just curious
I've seen tons of ppl have no clearance issues with the E7s on a stock '86 bottom end. Sure your heads aren't milled?
1 - 9 of 9 Posts
