1 - 14 of 14 Posts
Hey guys, just got the car tuned and dynoed at Walsh Motorsports. These are excellent guys to deal with and are very friendly. All the mods are in the sig. Might be able to post graph later.
On Motor: 295.6 hp and 326.5 lb/ft of torque
On 100 dry shot: 375.2 hp and 464.1 lb/ft of torque :joy:
Air fuel on motor stayed consistantly in the upper 12's and on nitrous it stayed around high 11's.
Don Walsh also took care of some drivability problems but the JMS tune was pretty dead on. Thanks go out to both. Now to get some track times.
Thanks, Matt
sweet nice #s.
so, how do you like that cam? how's it idle/drivability. can you stick it in 4th at 35 and cruize at 1500 rpms or does it buck unless your over 1900-2k?
Thanks, The cam idles nice. It does buck a little but nothing I couldn't tolerate if my car was my daily driver. The cure for bucking is just give it more throttle at all times :evil:
Matt
Just got my combo dynoed and only TFS thing i dont have is pistons and crank. Other then that got the R intake, stage 3 cam, RR's, TW heads. 420hp/470tq... nothing ported.
Are your heads and intake box stock or ported?
Mine are if your talking to me... no port work at all. Only thing done to the heads were larger springs to hold the bigger cam.
Not bad considering the mild cam and weak intake.
Time to step up to a larger cam and intake. Make on the motor what you are now making on the hose!!!! LOL!
Matt
I know that feeling! Do you run O2 sensors or do they make your car not run right?
yeah I run O2's in my longtubes. The bucking isn't as bad as the car warms up so the O2's might have a littke to do with it.
N20junky: Are your heads and intake, box stock or ported?
Is there a way to eliminate the O2's?? What problems would it fix?
SVT
Yea you can eliminate O2's, just unplug the connetor from the O2's to the main harness in the engine bay. I don't think its a good idea to do this but sometimes it does help bucking/driveability problems. My old combo wouldn't run for crap with the O2's connected, wouldn't even idle without stalling sometimes. These were brand new O2's also. I'm sure there would have been a way to keep the O2's and get the car to run right with some tuning, but I just couldn't do it.
I'm not running O2's with my new motor now either because I gave the O2 harness to my friend. I think if I had O2's now I could get the car to run better (car really starts to beak up from 2,000-2,500 rpm) Also some days it will run great and others it feels like its missing 100 horsepower.
Sooooo, anyone got a harness for sale????
1 - 14 of 14 Posts
