Got the car Dynoed today. Dont have a scanner, will post pics/video later.
Max HP - 290 @ 5300
Max Tq - 320 @ 3800
A/F was 12.3
Had timing at 18* and fuel around 35psi on best pull. Much better than the 16* and 39 psi I started with. The car liked more timing and less fuel. I run 24lbs injectors and a Crane ignition. 3926's with a .054 gap.
* TFS street heat intake
* Crane 2031 installed on a 112 IC
* Edelbrock 6037's (bowl work, exhaust port work, 3 angle w/30* back cut)
* BBK 1 5/8 LT's
Must say I am happy. Its still a little rich but I was out of pulls. Need to ditch these 3.55s for some real gears now. Later guys.
Discussion Starter · #4 ·
BigDaddy LTD LX,
Could you explain a little more what you mean? I am new to this.
MARK 302,
Just got 700 miles on the motor, no times yet.
