I was wondering if anyone has ever broken a motormount in their GT. I have a 98 GT with H & R Springs, Tokico shocks, Maximum Motorsports (Panhard Bar, Subframe Connectors, Caster/Camber plates) and polyurethane bushings. Ever since I put the suspension on, when I shift from 1st to 2nd gear my driveshaft slams against the underbody of the car on the emergency brake assembly. I have already changed the transmission mount but it didn't make a difference. The ony thing else I could think of being wrong would a broken motor-mount or my bushings are worn out in the control arms. I really like the suspension but I didn't have any problems till I put on. Also it seems like it only rubs on the better of the car when it is understress when I have it floored. Please help if you can.
You can get under the car and check the engine mounts out.
Or have some one gas your car and with the hood up look and see how much the engine is moving.
