1 - 9 of 9 Posts
I really hope this isnt a stupid question :eek: but i am about to install some new Brembo Cross drilled and slotted rotors and they aren't marked left and right and i am not sure which way they should be installed as i have seen them setup differently. Here is a pic of one way from Wilwood's site:
http://www.wilwood.com/products/kits/dpsfbk/hdfbk_big.jpg
I have seen other pictures with the slots going the other direction. Is there a proper way to install them?
Thanks.
I'm pretty sure they should be installed as shown in the picture so that the slots sort of 'scoop' air as they rotate.
I have slotted/cross drilled and Im pretty sure mine are the opposite from the pic shown, have to check in the morning.
Yeah, thats how i installed them on my Girlfriends mustang, but i saw them pictured different and i wanted to make sure i installed them on my car right (if there is a right way). :D If you look on Wilwood's site they have the fronts as pictured above and the rears are the opposite.
Well I checked and mine were opposite from the pic on wildwoods site. When I installed them they were marked left and right so I did it as per the instructions given.
OK, Thanks man. this is really weird, everyone seems to have them installed both ways, i wonder if it matters? :confused:
:confused: Is that the opposite of how wilwood has them set up?
looks that way to me. :confused:
I got brembo rotors so i will follow their directions.
1 - 9 of 9 Posts
