1 - 10 of 10 Posts
Does anyone know if the Dr.Gas x-pipe has the Air pump fitting or will I have to have one welded on?
None of the Dr gas x-pipes that i have every seen have had the air pump hook up.
Really? Do you have to pass emissions in FL?
What did you do with the air pump house.
I typically swap the h-pipe when it's inspection time so I can't delete my smog pump.
you could have a muffler shop weld one up, but none of them come with air tubes as they are "off road" pieces
the dr. gas piece is 100% offroad. No air tube fitting, and no cats. They do have nice welded on bungs for the O2s, solid flanges, and a very nice X section.
If you want to go legal I suggest looking at a bassani pipe...
Now this is odd. You can run short headers with a 100% off road h-pipe that has the fitting for the air pump but not long tubes?
This is crazy.
So my options are:
1.) Have the fitting welded in
2.) Take the hose off and by pass the smog pump with a short belt.
Is this right?
Now I'm really going crazy. I have been looking around and MAC.....yes MAC, that everyone says is crap, has a pro chamber for LT's with the air pump fitting.
I'm giving up.
if you run offroad x/h, then you don't have cats anyway and therefore don't need the air tube or pump.
1 - 10 of 10 Posts
