My head is spinning.
Can they be installed without welding? This way I can at least heard it and drive it to the shop to be welded.
Any other surprises I should know about?
i always thought they had to be, i may be wrong. i know mine is :)
IT will need to be welded. Some folks will get it set up close and use hose clamps to get them to the muffler shop.
Casey
Dynomax makes a band clamp that works good, it doesn't crush the pipe like a regular exhaust clamp does.
The only thing to consider is ground clearance. The Dr Gas X-pipe merges in front underneath the trans, so if your car is lowered that might be something to think about.
-Billy
get it welded, trust me
Thank you very much everyone.
One last question.
Will I be able to remove the x-pipe to put the cats on for emissions?
Oh, and what about the smog tube. I don't think the x-pipe has a connector. What do I do with that?
yep, i can pull my xpipe in 10min, faster if i had a lift :D (this is the shorty xpipe that works with LT's)
if you need a connector, you can always have a shop weld one on. they welded on hangers for me (for the tranny xmember)
