Any diffrence in the cross members for autos vs. 5spds? 87-93 models
gnocid5 said:
I have gotten some other replys that I have to grind off some welds and adjust it. The crossmember is from a 5spd and I want to use it in an auto.
There are no welds that you just "grind off and adjust". The single hump crossmember from the 4cyls have different mounting locations. They are about 4 inches farther back and even have their own mounts bolted to the subframe.
The 87-93 AOD equiped GT's came with the standard double hump cross members. You should be able to use one no problem.
if you put a c-4 in your car you must grind off the welds adn move the crossmember ends...but auto and 5 spd are the same.
