get a bolt about 2 inches long and 2 washers a socket and a nut.
put a washer on the bolt then the bushing insert it through the door hinge ,then put on a socket (to take up extra space) and the washer and nut. tighten up the nut and it will push the bushing into place. it made it a lot easier instead of trying to pound it in.
:joy:
Super Moderator
why does everyone have to pound or press these in now? THey used to just drop in place.
Mine dropped right in.
maybe your hinges had wallered out? mine didnt- maybe that was it.
a side was ground down on the bushing so my door sagged and i had to pull it up to close it.
would aftermarket parts have anything to do with it? i didnt get the factory ford parts 2.99 for A bushing and 7.99 for ONE pin. dont thnk so... 8.99 for the kit of 4 bushings, 2 pins and 2 cotter keys from The Paddock.
i just used sawzall and about 5 blades after it kept bouncing off the back of the door and bending the blade.
