It's been 9 years since I posted an update but I have many. I have continued work in the car in a variety of areas both in terms of maintenance and upgrades. Here is the list of updates:
Suspension
Added a MM X-Member, A-Arms and coil over kit
Updated to a 2003 Cobra steering rack
Upgraded to 1996 cobra spindles and drilled tie rod mounts
Upgraded to Cobra rear brake kit (and replaced seals and calipers)
Upgraded to powder coated PowerStop rear calipers.
New pads/rotors front and rear.
Upgraded to the Cobra Master Cylinder & lines (for less volume and better pedal feel
Replaced leaking pinon seal.
Replated both rear Saleen wheels. They started leaking at the bead. I'm probably going to need to get new wheels pretty soon.
Switched over to 295/35/18R & 255/40/18F Michelin Pilot Sport tires - tires were getting old
Fuel System
Completely switched over from -10 /-6 Socketless to a -10 / -8 PTFE lines - Sockless were smelling and getting crusty
Installed a Glenns performance Sumped tank and VDO sender
Engine
Welded upper intake with additional aluminum support
Fox Lake ported and welded GT 40 lower
Fox Lake Stage 2 CNC TFS TW heads along with new valves, valve springs to support hp level
Swapped in new high performance ford lifters
Replaced Dorman Cam sensor with actual Ford brand Cam sensor
Recoated hotside and added a vband midway on downpipe
Modified crossover pipe to work with motor in rearward position
Shortened cold side discharge pipe to get better ground clearance
Switched to solid motor mounts
Rerouted and got all new plug wires. The heat ate them
Added additional heat shielding in may areas
Filled and painted entire engine bay when motor was out
Re-wrapped entire hot size in Lava and ditched the fiberglass wrapp
Switched to Lava turbo heat shield
Replaced AC drier
Replaced Fan motor and melted connector - this was pretty crazy. If you have a 94-95 check this connector!
Installed a new Stewart water pump. The old one was weeping.
Upgraded to 1996 cobra AC condensor to improve cooling and AC perf.
Upgraded to a new high torque starter
Upgraded to a Group 34 Optima battery (twice).
Switched to a 3 PSI boost spring and AEM boost controller and then back to the 9 PSI spring that I originally had installed - low psi springs don't work well I found
Added Catalytic convertor heat shield to reduce undercar heat
Electrical
Added back up camera
Installed latest double din Apple Carplay flagship Pioneer flat screen head unit
Converted fiberglass sub box from ported to sealed
Carpeted sub box and finished installation
Switched from P3 subwoofers to DVC power series subs
Added temperature controlled push/pull fans to cool amps with 3d printed fan mounts
Replaced clutch sensor & starter relay - Had some strange hot non starts
Body
Added Carbon fiber fan shroud
Upgraded to the FR500 wheel with red stripe
Replaced front bumper core - Old one looked cheap and was cracked in a few places
I'll follow up with pictures as time permits.
Suspension
Fuel System
Engine
Replaced AC drier
Electrical
Body
