Update
I have a couple things to report. First off I ended up having some paint work done to tighten things up a bit. The hood, bumper , back quarter and one interior trim piece was painted. It was decent work by Bel Red auto in Kirkland, Wa.
More recently I have been working on updating my stereo system. I had an old alpine system from 2001 which was quite large (head unit, dvd, changer, brain box etc) that I have replaced with a newer DVD double din setup from pioneer (Z2).
After looking around at what people have done to convert their <01 cars to double din I decided that I wanted to as closely replicate the double din in the 2002 + cars. I purchased the following:
1) A 2003 cobra dash bezel & shifter bezel (with leather boot) $75
2) A metra double din aftermarket radio for 2003 mustangs $75
3) A ac delco 3 wire cigarette lighter plug and lanyard from a 2003 hummer (chevy part was almost 20$ cheaper than the 2003 ford harness and its identical) $25
4) 3 blanks for the bezel from 5.0 resto for around $30
5) A blank for the cigarette lighter itself from ford.com $18
6) A 2005 mustang GPS bezel from Ebay. Color was wrong, but I had other parts that were being painted so no biggy. $50
Here was what the cobra bezel looked like when it showed up. Mechanically in perfect shape. Cosmetically not so much. No matter though I wanted it to match the rest of my car.
After reading on the net one thing that is universally true is that you must cut the tabs on both sides of the original dash. If you look at the below picture you can see that I have done quite a bit of trimming of the upper and lower dash bezels.
The secret sauce of my setup is a custom steel bracket I made for holding in the radio. The bracket mounts to factory holes and provides enough strength to hold the radio in the right spot. This took quite a bit of measuring, but It was close enough on the first shot to make it work.
I also took the opportunity to replace the rubber grommet around the shifter which was very beat up. You cannot really see it in this picture, but the cigarette lighter leads were cut and the AC delco 3 wire plug was soldered in. You cannot really see the wiring in this picture, but everything was soldered in and heat shrinked where possible on the radio. Taps and butt connectors do not last in my experience.
After thinking long and hard about mounting locations for the XM and GPS antennas, I settled on the trunk lid. As it turns out the aftermarket 2005+ Mustang antenna cover is the perfect size to fit over the Pioneer antennas.
I used a grommet on the hole and then loomed the wires all the way up to the dash
The finished setup looks decent after a quick paint by Bel Red. I really like the newer Cobra bezel there are no open/shut rollers which is clean (and who needs them anyway) and obviously the double din is much more functional.
I am currently working on pulling out the 90s vintage alarm and updating that as well. More on that soon.
