Ok. Make sure to bring some depends.I'll be over for a ride soon.
So I had a few electrical problems. The first major issue was a loose alternator feed wire bolt. This smoked the plastic around the alternator and melted down the rectifier. This was easily fixed by PA for a few bucks. The second major issue I had was a loose engine ground and also a loose fuse box feed wire. I was able to reterminate the wires to get these working.So what pin out problems did you have? I have my entire harness from ECU to each component laying on a table right now. My plan is to check each line one by one to make sure they are correctl; then check again.
I got it off of ebay from specialcarbonfiber . Here is the listing:The car looks way clean man! Who makes those cowl deals, I have seen them before. Did you just re-furb it or did you actually make it.
I got it from racer parts wholesale. Racer Parts Wholesale - Racing Parts, Safety Equipment & Motorcycle Accessories They have good prices on quite a few things including aeroquip. Unfortunately the cooler was not in stock so it took a while. I also purchased the setrab oring to -10 socketless fittings with it as well since the cooler didnt have standard npt or an fittings on it to begin with.Where did you get your Setrab cooler from? I'm looking into one for mine while I have it ripped apart.
Do you think your problems would still be there had you used the EPM instead of the ford parts? How helpful have the guys at AEM been?It's running.It has never really been tuned properly though.....and it has a inconsistent misfire at around 5k the origin of which I have not been able to identify. Originally I thought it was an ignition problem so I replaced the plugs but that was not it. It's most lilkely a fueling issue I am thinking.....
I also have some startup delay which has been frustrating. It usually takes 3-4 seconds to fire. This is partially the startup enrichment and partially the time it takes to get a crank sensor signal that is strong enough to fire the ignition. I worked with AEM on this which made it a bit better but it still needs improvement.
I also have some serious vapor coming from the charcoal canister or through the fuel lines which is a bit irritating. I have a new charcoal canister that i need to pop in to see if that will help....
Lots of finishing details.....
Take some pics of your lines and post it. I would love to see how that worked out. The factory lines are real cheap to replace, but are not routed right at all imho.Just scrolling up I noticed the P/S post. It looks very good. What did you use to paint the resivior?
I ditched the factory lines in favor of steel braided teflon and -an fittings. So much nicer now. Figuring the return from the cooler to the bottom of the pump was a little bit of a challenge though.
