before when i did this the car would just die,now since
my hanging idle started from a cross state drive it stays
running when i pull the hose off.help,this hanging idle is driving
me crazy.just started doing it all of a sudden
Either you have a big vacuum leak or you need a new iac valve. Check your pcv valve too, mine stuck open causing problems like that.
Bob
thanks bob,i will check it when i leave work.its kinda weird it just started sat.the car always had a tendency to idle and die,not it just idle up and hangs between 1500-2000 rpm for a few seconds before falling back.what is the proper idle for a stock 2v motor ?
Randy
