I am interested in doing a ultraflo welded cat-back, but would like to use a 3" exhaust following the stock exhaust route. Do they have a kit? I may even consider a super turbo kit if it is available.
I have to follow the stock ehaust pipe routes in order to use the MM pabhard rod, but i need the 3" for my soon to be built 427 stroker.
Any help, info, or good advice would be appreciated.
USAF retired
http://www.tenneco-automotive.com/frames/dynomax.html
The website has all the specs on the different mufflers. I bought 3" superturbo, I think they were hemi turbos but the passenger side wouldn't fit because the driveshaft is offset to one side. It might have fit with the stock driveshaft but would be very close.
I have seen a 3" exhaust advertised in the magazines or get in
touch with Buddy Rawls about it and your combo you're building.
David
Discussion Starter · #4 ·
Thanks for the info. Now I know it can be done, just not as easily as a 2.5" set-up.
