the Turbo Coupe WAS a 4 cyl car.4 cyl cars got the 7.5 too. unless it was a turbo coupe T-bird.
That article is incorrect. All Mustangs (excluding specialty models which I can't say for certain) up until the S197's came out had 28 spline from the factory. The V6 uses a 7.5" rear end, not an 8.8 and it was also 28 spline, but came with a 2.73 rear gear. I've had a dozen or so SN95 Cobras and every one of them had 28 spline from the factory.
But Ford confirmed the 8.8 by VIN number?Someone changed the axle housing in your car. All SN95 V6 Mustangs came with 7.5" axle assemblies.
1fafp4045yf134386That's impossible. The VIN number doesn't contain any information about the rear axle assembly. See the site below for an example of how to decode the VIN number.
2000 Ford Mustang VIN Information
Decode the 2000 VIN numbers and data sheets with our easy to use guide and tables.www.mustangspecs.com
I'm confused. I called Ford parts and gave them the last 8 of the VIN. 8.8, 3.27GR and limited slip they said. Limited order maybe?1fafp4045yf134386
