I have a 2002 Gt with automatic tranny and the mods listed in my sig. rwhp 227.4 rwtq 272.4 my car was running 14-15 for A/F would that have an effect on my low numbers?
Discussion Starter #2
bump
Stock=260*.8=208 rwhp
Stock=302*.8=241.6 rwtq
Your numbers seem OK to me.
Those #s put you somewhere around 275hp 'ish and 325-330ft lbs @ the crankshaft. Considering that your car is an auto, and the only things that you have done to the car that would actually give you (some) power increase are exhaust and a powertuner (chip), those look like pretty good #s to me.
As far as the A/F ratio is concerned, 14.7:1 is stoichiometric (ideal for burning all fuel / air entering the combustion chambers), so 14-15:1 is right where you need to be A/F ratio wise. Any higher and you will begin to loose power (and experience pre-ignition) due to a lean condition, and if you go much lower than that, you will likely be losing power due to it being too rich.
John C.
Your numbers look normal but your A/F is lean. While 14.7 A/F is ideal on paper, you want to be around 13-13.5 on a N/A car in the real world.
#'s are fine, mine did 230 with mods before my exhaust and intake setup :mad:
Whats mods did you have when you dynoed at 230?
