i have a set of aftermarket valve covers and just put some cork gaskets on with a thin layer of blue rtv. will i have a problem with leaking?
Discussion Starter · #2 ·
I have cork gaskets on mine, and the only problem I have is keeping the Valve cover gaskets tight. I have to go back in and tighten them up ever 6-9 months.
The RTV should help you out though.
Why using cork gasket? Spend the money and get good Ford gaskets, they are steel reinforce with molded rubber on it, they are reusable and last forever.
