I am running an 87-93 offroad bassani in my 94 cobra. Fakesnake is correct. You have to cut the fox hangers completely off. I made a simple bracket that attaches to the stabilizer bar(the flat bar running between the two pipes, you will know what I'm talking about when you see it).
I used a piece of sheet metal about 3" by 3" or so and bent the piece in an "L" shape. I then drilled two holes in the center of the bar I just mentioned and 4 holes in the sheet metal(2 to attach to the stabilizer bar and 2 to attach the rubber hangar mount) Should take you about 10 minutes to make. If you have any questions let me know.
