Ive heard some mustangs did, but i dont think mine did. Anyone have any hard info on whether or not the 94 verts had subframes stock? If not, whats the best kind to get. Thanks
Mark
I don't know how much this will help but my 95 Vert didn't come with subframes. I used MM.
Henry
No they did not, but I do believe the newer models do. they are a "short" connector design though. I have the full length GW units, I've seen a lot and these are by far the best I've ever delt with, but I've never seen the MM units on a car.
Every Mustang ever made has subframes stock. Subframe connectors are a different story.
Even the 94 Cobra verts did not come with sub frame connectors.
MM has some good ones, I have the standard ones and they do a good job, but I wish I would have got the MM full length sub frame connectors.
I does not matter which brand you get, just get some.:)
The convertibles do have a factory K-Member brace that extend and weld to the subframes... With welded on subframe connectors the convertibles really handle tight.
