does anyone want a distributorless ignition setup for their car or truck I had it in my 66 mustang and it works great but I am wanting to go to carb setup for easier tuning it comes with everything you need to install harness computer cam sensor crank sensor harmonic balancer fit standard 302 crank 82 and up all o2 sensors engine coolant sensor maf sensor air intake sensor both coil packs and mounting bracket this is a complete setup all you have to do is hook up a power and a ground plug the injectors in and your done it alread has its own fuse box and is already wrapped in covoluted tubing as you can see by the picture the fan is turning so obviously the engine is running so you know it works I would like to get $350 out of this but its not set in stone so let me know thanks
Discussion Starter · #2 ·
anyone
