I just bought a msd distributor and need to change the gear from a iron to a steel gear. what is the best way to get the old gear off
and the new one back on ?
You'll need a press. Before you press it off though, take some measurements so you can make sure the the gear is sitting in the same place.
Any machine shop should be able to press the old one off and the new one on for you pretty cheaply.
Use a press. The new gear comes with instructions and the specs for installing the gear in the right place.
