between one from the dealership and one from Kragen.
I've been having problems with the one's from Kragen they are brand new and not the refurbished ones.
Does ford make a ford specific?
Could that be the reason why i keep killing the regulators on the previous alternators?
Its probably something wrong with your charging system, everybody blames the alternator. How old is the battery?? Even new batteries can be bad. Are you fully charging the battery BEFORE you install the alt? if not your working the alt to death right there. Check all your grounds and have someone do a voltage drop test from your alternator to your battery and see what you get. I build alternators and starters for a living and I can tell you that most of them that come back arent bad.....
Get one from Autozone or Advance, they will be the product that I manufacture at Delco Remy, and should be better than the crap from Kragen.
Discussion Starter · #4 ·
thanks guys for the info i tried autozone they couldn't find the right alternator part # so that's why I went to Kragen
