1 - 14 of 14 Posts
Does it become bad again in a couple of days?
yeah, on my 99gt, i cleaned it, and it did nothing. replaced the IAC, and it didnt help anything, either.
on my 95gt, i just cleaned it, and now the idle is worse.:rolleyes:
I took mine off the car, filled it up with carb cleaner, covered the tubes with my fingers and shook it for a minute and poured out the nasty stuff. I repeated this until the fluid came out clean and made sure that the little plunger moved freely. I also used a screwdriver and a rag to wipe what parts of the plunger and surrounding areas I could reach. No problems since. This was almost a year ago.
I drenched mine in carb cleaned, used WD-40 on it as well, and got a small razor blade to get the junk off of the turning piece. It fixed my problem majorly. My car would stall everytime you pushed in the clutch, hasn't done it since. (knock on wood!)
I used carb cleaner and a method similar to Mo-D's about 6 months ago and have had (0) IAC problems since. Give it a try, can't hurt and may save you a few bucks.
There's plenty of threads on this, but I did the same.. carb cleaner until it cleared up completely.. haven't had a problem since
Will electrical contact cleaner work?
Do I need new gasket?
Torque spec on bolts?
Thanks.
Where is the IAC located? Does anyone have any pics of where it is? I can't find any pics, and I'm not familiar enough with our cars to be able to point it out.
If anybody wonders accordingly to Helm manual torque spec is 75-106 lb-in, which is hand tight.
Yep, took mine out, sprayed it with Carb cleaner. 15,000 miles later, still no problem.
i just walked in from cleaning my IAC and i'm hoping it solved my problem. my idle is really bad. i sprayed it down really good with electrical parts cleaner. when i started it up it still seemed a little rough, although i havent taken it out yet or kept it running for very long. i'll try later and see how it goes.
After you clean it, make sure you move that piston back and forth. I still have my original IAC after 206K but I've cleaned it 3 times now.
Erich
ERICH....
...Your Killin' Me :D
c'mon, iam trying to make a buck here!!
200k on the oem IAC?:eek: ?
(i'll give you my spare)lol
Randy Stinchcomb
p.s. Erich, your car is amazing:)
say"hi" to Sue
1 - 14 of 14 Posts
