I posted this over on eectuning.org, but didn't get any responses, so I figured I'd try here.
I recently disabled the WOT vs rpm functions in BE and adjusted my sea level table (disabled altitude spark table) to accommodate. My peak timing should match what I had for the WOT spark vs rpm (or close to it).
What I see is that the timing in my data log does not match what I have entered in my sea level table. At WOT, it seems like all my actual values are about 2 degrees (or more) less than my sea level table at that same rpm and load.
One example, at WOT, 4000rpm, 90% load, I should be at 32 degrees per my sea level table, but the datalog is saying around 29.8 degrees.
EGR disabled.
Load%=Load
When I had the WOT vs rpm functions active, datalog timing match that spark function.
I looked through all the scalers, functions and tables to see if I could find why, but coming up empty.
Any thoughts for why my data log timing doesn't match my table?
BTW, I don't have my blower belt on, so this is currently NA
EGR disabled.
Load%=Load
