Not sure if this is the right thread, but i'll give it a shot.
my 1992 foxbody Dash Guage Lights work well except right in the middle, the left side of the speedo light has gone out. is there any way of replacing these lights? its very irritating!!
I'd like to know also. The right side of my speedo doesn't light up at night. Anyone know the part number of the bulbs that need replacing?
Buy (I think 19 bulbs) part number 194 remove the cluster assembly and unscrew all of the black or grey colored plastic bulb holders and swap out bulbs. Probably more of a hassle to disconnect the speedo cable than anything...
you have to pull the column shroud off, the bezel around the cluster, which usually means removing the knee bolster. disconnecting the headlight/hazard plugs are a little rough. then theres 4 bolts holding the clusted in. pull the right side out first, disconnect the connector, then the speedo, then the left connector.
there are little black things that hold the bulbs in place.
