+26 mm would tuck inside more.
+26 mm would tuck inside more.I'm still in for what ever tucks the wheel furthest inside the wheel-well.
If that's true, I've got it backward - I thought 29.5 was the deeper backspace.+26 mm would tuck inside more.
Thanks for the info, I really appreciate it. And I'm sorry for bringing down the I.Q. level on this thread with my ignorance.Paypal is very flexible and convenient, it can be set up to pull money either from a checking account (with a CC backup) or directly from a CC. I use it to buy things online and have it set up to pull from my Mastercard, so it shows up on the CC statement like any other purchase. It's been awhile since I looked at what they have to offer, there may well be other options now. I recommend you go there and set yourself up, it costs nothing for you to send a payment, it only costs the seller to recieve it, like when they accept a CC payment; so they consider it a cost of doing business.
-MJS
If this information is true then I would want the 29.5mmJust thinking of listing some pros/cons for each offset we're considering. Any others I’m missing?
+26 mm offset pros
Provide more fender clearance for those who use 96+ spindles and/or most aftermarket K-members.
Provide more fender clearance to run a wider (275/40) tire up front.
Help with fender clearance issues especially if you lowered your car over 1.5”.
Will this not help provide more REAR fender clearance for those with SN-95 axles and wide tires?
+29.5 mm offset pros
Help those who plan on widening these wheels.
Help fill the wheel wells for those with near stock Fox length axles (sit closer to the outside).
I don’t think these offsets are a big issue for the rear of our cars, weather you have stock length or SN-95 axles. I think the issue comes down to front fender clearance and widening the rear wheel. Yes, I’d prefer the +26, but we can flip a coin for all I care =). I’ll let those with front clearance/widening issues decide what we do and I don’t think the 3.5 mm between the two will really be a show-stopper for either camp. MHO-FWIW
Yes 3.5mm (.14") is less than a 1/4", but it is actually closer to an 5/32". :hammer: Sorry, I'll shut up now.3.5 mm is less than a 1/4",
You have it backwards.Just thinking of listing some pros/cons for each offset we're considering. Any others I’m missing?
+26 mm offset pros
that's what I was thinking from the beginning??? How could more BS possibly make the wheel stick outside the fender?? Bottom line: the greater the BS number the further it tucks the wheel under the car. So if you have aftermarket K-member, longer front control arms, and 94+ up spindles you would want the 29.5mm BS to keep the wheels from bulging out of the front fenders.
All true, and it also gives you more tire to fender clearance on any other combination front and rear.that's what I was thinking from the beginning??? How could more BS possibly make the wheel stick outside the fender?? Bottom line: the greater the BS number the further it tucks the wheel under the car. So if you have aftermarket K-member, longer front control arms, and 94+ up spindles you would want the 29.5mm BS to keep the wheels from bulging out of the front fenders.
Since most 5 lug kits use SN95 spindles/rotors and 5 lug stock fox length axles then it seems that I will need/prefer the 29.5 bsthat's what I was thinking from the beginning??? How could more BS possibly make the wheel stick outside the fender?? Bottom line: the greater the BS number the further it tucks the wheel under the car. So if you have aftermarket K-member, longer front control arms, and 94+ up spindles you would want the 29.5mm BS to keep the wheels from bulging out of the front fenders.
fixed...Preferred Offset List
#1 Alexandros 29.5mm
#2 yellow&blcak95gt
#3 CobraSteve 29.5mm
#4 Fastfox400 26mm
#5 fromme 26mm
#6 scsvt 26mm
#7 STREETFIGHTER50
#8 JimJr 26mm
#9 jkcobra98 26mm
#10 blk50cobra
#11 robh
#12 mlanoux 29.5mm
#13 runin1320 26mm
#14 umachnme
#15 88gtconvert
#16 MJS 29.5mm
#17 93kingcobra
#18 aaronlstiles
#19 awilson 29.5mm
#20 oldtimer
#21 yellowcar2
#23 jw33 29.5mm
#24 93svtcobra
#25 ArtZarateJr.
#26 knuckles4696
#27 KC/Cobra
#28 Glasnost 26mm
This is updated. Everyone else needs to chime in on offset. Remember 17 x8.5, 26mm or 29.5mm offset.
changed my offset seeing the new diagrams...sorry about that.Originally Posted by Alexandros
#2 yellow&blcak95gt
#3 CobraSteve 26mm
#4 Fastfox400 26mm
#5 fromme 26mm
#6 scsvt 26mm
#7 STREETFIGHTER50
#8 JimJr 26mm
#9 jkcobra98 26mm
#10 blk50cobra
#11 robh
#12 mlanoux 29.5mm
#13 runin1320 26mm
#14 umachnme
#15 88gtconvert
#16 MJS 29.5mm
#17 93kingcobra
#18 aaronlstiles
#19 awilson 29.5mm
#20 oldtimer
#21 yellowcar2
#23 jw33 29.5mm
#24 93svtcobra
#25 ArtZarateJr.
#26 knuckles4696
#27 KC/Cobra
#28 Glasnost 26mm
