Sorta but I split it into 3 to make it easier to count.MJS said:Edit - I tried to make two columns, but the forum software put them back next to the names.
#1 Alexandros......................29.5mm
#2 yellow&blcak95gt..........................26mm
#3 CobraSteve..................................26mm
#4 Fastfox400...................................26mm
#5 fromme........................................26mm
#6 scsvt..........................................26mm
#7 STREETFIGHTER50................................
#8 JimJr.............................29.5mm...........
#9 jkcobra98.....................................26mm
#10 blk50cobra..................................26mm
#11 robh............................29.5mm............
#12 mlanoux.......................29.5mm............
#13 runin1320...................................26mm
#14 umachnme....................29.5mm...........
#15 88gtconvert
#16 MJS.............................29.5mm...........
#17 93kingcobra...................29.5mm..........
#18 aaronlstiles....................29.5mm..........
#19 awilson.........................29.5mm..........
#20 oldtimer............................................
#21 yellowcar2........................................
#23 jw33............................29.5mm..........
#24 93svtcobra................................26mm
#25 ArtZarateJr................................26mm
#26 knuckles4696.....................................
#27 KC/Cobra......................29.5mm..........
#28 Glasnost.......................29.5mm..........
#29 1992GTdrop...............................26mm
#30 93Cobra#2771...............29.5mm..........
So is this still a one off through Jeffo or now a production run through Wheel Replicas?Ok, Jeffo I PM'd the remaining four people to tell them to return to the forum and vote on the offset. As soon as we know I will either PM you or call you at work.
Alex
This is the exact combo I will be running. Currently I have the '94-'95 spindles with the SN95 rear axles, (M2300K kit) with the M-179 6.42 BS '95 Cobra R wheels.so what can be done the necessary 1/8 spacer for those of us using the stock rear track and 94-95 spindles?
Would it be possible for you to make these Jeffo?
