If you are looking to do some custom interior on your Fox door panels and don’t want to pay the crazy LMR/TMI pricing for the already covered versions, there is hope.
I am making/selling these door panel boards for the Foxbody years with a map pocket. These are based off an OEM template and I am using the same type of wood and thickness (1/8”) as original.
There are manufacturing marks, but these should not affect fitment/finished look.
All you need to add is your foam and vinyl/fabric of your choosing and BAM, custom door panel inserts.
Hardware is not supplied but can be easily sourced. One option is brass brads about 2” long. Just put them in first and then cover. Be sure to staple them after you attach them to the door panel to make them extra secure. I used these plastic pieces I had on hand with speed nuts, but feel free to use whatever you want. If I did it again I would go the brass brads route The holes are marked for the proper placement to go into the door panel board.
Going for $60/set (top and bottom for 1 door) shipped to the lower 48.
Here is what I did with mine and what you will get in the package(4 boards).
Discussion Starter · #2 ·
Here is how they look installed.
Ttt
Discussion Starter · #5 ·
I only have these templates at the moment
