I helping my friend put on TFS Twisted wedge heads and he wants a new cam for his 92 LX with a AOD. We are looking at these two cams. Would either of these two cams work with Twisted Wedge heads? And which one would be the best cam for a auto with stall converter?
how much gear? tire height? stall?
what is the compression ratio, and what intake.
I like my 511 with 1.7s
with an auto Id go with the smaller one, keep as much low end as possible.
stock compression, street heat intake, 3.73, 25.7 tall tires and stall is 2800rpm.
well you "might" be happy with the 512 (probably need 1.6 rockers) dont know what you have. It would probably like a little more compression.
GLENN had a 5 speed car running 11.8 with that cam performer heads and RPM intake, It was a drag mostly car though not much to drive on the street. It is a descent bit lopier than mine.
id still say go with the smaller of the 2 and 1.7 rockers.
If those are the only options of course. custom would be the "best" way to go.
